The Benefits of a Healthy Home
Healthy homes are just as important as energy-efficient ones, but why not have both? Making your home more energy-efficient can improve the health of you and your home, enhancing physical and mental well-being.
What does a healthy home look like?
A healthy home plays a crucial role in tackling a range of health issues.
- Good indoor air quality
- Comfortable indoor temperatures
- Natural light throughout the home
- Energy-efficient solutions
How can I make my home healthy?
Heat Pump
An air source heat pump keeps your home at a gentle, steady temperature all day compared to having the heat on, then off with a gas boiler.
Draught proofing
Controlling the ventilation in your home is different from draughts entering your home. Draught proofing means sealing up gaps in your home where unwanted cold air is coming in, which can cause damp and mould. Proper ventilation will ensure healthy air circulation.
Ventilation
Every home needs healthy air circulation. Good ventilation lets fresh air in and stale, moist air out, so you’re not stuck living with condensation, damp and mould. Mechanical ventilation with heat recovery (MVHR) lets your home have good air quality without losing any heat.
Insulation
A well-insulated home holds in the warmth in cold weather and helps cool down your home in the summer months. A properly insulated home will be able to keep your home at a consistent temperature, reducing the cold spots where mould and condensation can arise.
Solar Panels
Solar panels won’t necessarily make your home healthier in the traditional sense, but the money you can potentially save means one less thing to worry about. A home you can afford to heat is a healthier home all year round.
How to make your home healthy
Assess your home
Get a plan for your improvements – plus get 80% off voucher for a range of assessments.
Get a VoucherFind a Contractor
Find a product specialist or skilled installers to bring your retrofit projects to life.
View the Directory
