The Benefits of a Warmer Home
Energy-efficient improvements keep your home warmer in winter, but did you know they can help keep it cooler in summer too? Insulation is a great example.
Making your home more energy-efficient means a warmer, cosier place to live, whatever the weather’s doing outside. Solutions like an air source heat pump, draught proofing, or good insulation don’t just cut your emissions; they can save you money too.
How Energy Efficiency makes a Warmer Home
Energy-efficient improvements keep your home warmer in winter, but did you know they can help keep it cooler in summer too? Insulation is a great example. It sits within your walls, loft or floors and slows down the movement of heat, so in winter, the warmth you’ve paid to generate stays inside for longer, and in summer, the heat from outside has a harder time getting in. That’s why a well-insulated home tends to feel more stable and comfortable across the seasons, rather than swinging between freezing and stuffy.
Temperature Controls
Heating Controls and Smart Systems
Heating controls are one of the most cost-effective upgrades you can make to your home. They do not change how your heating system generates heat. They change how intelligently it uses it. The right controls mean your home is warm when you need it, not when you don’t, which reduces wasted energy without compromising comfort. Even modest improvements to your heating controls can cut your energy bills noticeably.
Benefits of Smart Controls
As well as helping you save on your energy bills, smart thermostats let you control your heating from your phone, wherever you are, and give you a clearer picture of how much energy you’re using.
Smart Valves
Smart valves take things a step further, letting you control the temperature room by room, so you’re not heating rooms nobody’s using.
How to make your home healthy
Assess your home
Get a plan for your improvements – plus get 80% off voucher for a range of assessments.
Get a VoucherFind a Contractor
Find a product specialist or skilled installers to bring your retrofit projects to life.
View the Directory
