Cavity Wall Insulation
As approximately 35% of heat loss occurs through uninsulated cavity walls, CWI proves to be highly effective in enhancing the thermal efficiency of your home and reducing your energy bills.
The Importance of Assessment
Cavity walls can be built using various methods, and not all of them are suitable for insulation. Therefore, it is crucial to conduct a comprehensive pre-assessment and borescope inspection before considering it as an option. Some older cavity walls are constructed with brick bonded ties, which are not suitable for cavity wall insulation (CWI) since it permits the transmission of water between the external and internal leaves. The modern approach of using metal ties to connect the wall layers is the preferred method for CWI. Additionally, historical construction techniques have resulted in diverse nuances and uncertainties. For instance, some street-facing walls may be solid, while side walls could have early cavity construction. At times, brick facades may conceal an internal timber structural frame. The key takeaway is that thorough investigations, including measuring wall thickness and identifying construction types, are indispensable in determining the feasibility of installing CWI.
Why We Have Cavity Walls
Traditional construction methods (solid walls) are prone to water penetration and rising damp due to their porous nature. From the 1930s onwards, construction methods changed to reduce this risk by building external walls with cavities, which prevents water from being absorbed on the internal leaf of the wall. Since the 1980’s, new build cavity walls have commonly incorporated partially-filled cavity insulation to meet Building Regulations to improve the thermal efficiency of properties. Those that remain empty are significant (around 5 million homes) and present an attractive retrofit opportunity for many. As a result, CWI has become a widely adopted standalone retrofit measure, however there is still a significant number of homes across the country which remain unfilled.
Benefits & Characterisitics
Minimal disruption
Minimal disruption
Cost effective solution
Reduced Energy Bills
Reduced Carbon emissions
When is Not Appropriate to Install CWI?
  • If there are visible signs of rising or penetrating damp on the inner surfaces of the masonry.
  • When there is clear evidence of an obstruction in the cavity or the presence of a brick tie that could potentially channel water toward the inner leaf.
  • In cases where structural damage is apparent, such as cracks or spalling in the outer leaf, it is essential to address these issues before proceeding with installation.
  • The presence of external render may indicate a prior wall defect that has been concealed, and this needs to be assessed.
  • When the cavity is currently used for combustion purposes, such as a fireplace, or for ventilation needs.
Assessor in a home looking at potential renovation plans for the house - Retrofit West
What Can I Save?
The table below provides an indication on your energy bills (£/year) and the amount of C02 emissions (kg/year) you could save by installing cavity wall insulation.
Detached HouseSemi-detached HouseMid-terrace HouseDetached BungalowFlat
Typical Installation Cost (£)£4300£2700£1500£2000£1100
Energy bill savings (£/year)£420£240£140£180£120
Carbon dioxide savings (kgCO2/year)1100kg650kg380kg490kg310kg
Source: Energy Saving Trust– estimates based on insulating a gas-heated home. Costs may vary significantly depending on the level of work required. Above estimates are based on a typical install, ranging from a small flat to a large, detached house. Prices are based on fuel prices as of July 2025
Cavity Wall Insulation FAQs
