Heat Pumps in Conservation Areas
With the help of Steven from CSE, David unravel the challenges of installing a heat pump and reducing heat loss in a conservation area.
Installing a heat pump for your home is more than likely considered permitted development, so you don’t need to apply for planning permission unless you live in a conservation area. You will need to contact your council to check their requirements before installing heat pumps in conservation areas.
David has always thought if a heat pump is right for his home? Living in an older styled home, unsure if a heat pump is suitable, David has been doing research about what he needs to consider to see if a heat pump would be a good way to heat his home. This video by the Centre for Sustainable Energy breaks down the research he’s conducted and what help is available to see if a heat pump is suitable for your home.
Installing heat pumps in a conservation areas can present a unique challenges due to strict regulations which intend to preserve the historical character of these locations. However, it is possible to install heat pumps in conservation areas by following specific guidelines and working closely with your local authority.
  • Each local authority will have specific guidelines for conservation areas, detailing permissible changes.
  • Making sure the visual impact of buildings is minimised and they can’t be installed on a wall or roof which fronts a highway.
  • Consulting with local planning authority and a conservation officer which can provide guidance and help identify any issues early on.
