Why is Airtightness Important?
In homes, maintaining airtightness is essential for thermal efficiency; however, unsealed gaps, typically around windows, doors, and service entry points, can significantly compromise this efficiency.
What is Airtightness?
Airtightness is crucial in regulating the thermal efficiency of your home. In older or poorly constructed properties, gaps in the outer structure can lead to uncontrolled air leakage, causing colder draughts internally and loss of heat externally.
Gaps often occur around unsealed windows, doors, and areas where services penetrate the building fabric. Identifying and addressing these openings is crucial for optimisation.
How does retrofitting help improve airtightness?
Retrofitting provides an opportunity to enhance airtightness through insulation upgrades, taping or sealing services, and addressing draughts. These measures collectively contribute to a more energy-efficient and comfortable living space.
Retrofitting your home allows for improving airtightness, directly enhancing thermal comfort. By addressing gaps and implementing insulation upgrades, you create a more energy-efficient and pleasant indoor environment.
How can I assess my home’s performance?
The testing is a valuable tool to evaluate your home’s existing performance. Additionally, thermal imaging surveys can pinpoint specific leaky spots, offering a comprehensive assessment.
Is it recommended to use both airtightness testing and thermal imaging surveys simultaneously?
Yes, combining both survey methods concurrently is recommended where possible. This dual approach provides a more thorough understanding of your home and identifies areas for improvement, ensuring a comprehensive solution.
Homeowner Assessment Voucher
You can take advantage of our very own Home Assessment Voucher where you can get 50% off. A number of our trusted suppliers offer Thermal Imaging Survey’s which will help you identify where you will be loosing heat and identify thermal lose in your home.
Home Assessments
A thermal imaging camera help up in a building - showing the cold and hot spots in the home
