Electric Heating
Overview of Electric Heating
Electric heating covers a broad range of technologies – from the old-style storage heaters found in many off-gas homes to modern infrared panels and electric radiators. It is increasingly considered a low-carbon option as the electricity grid becomes greener through the growth of wind, solar, and other renewable sources.
Electric heating is not always the most cost-effective primary heating solution. Electricity remains more expensive per unit than gas in the UK, but for homes off the gas grid, flats where a heat pump is impractical, or rooms needing supplementary heating, it can be a practical and increasingly clean choice.
There are five main types of electric heating, each suited to different circumstances.
Types of Electric Heating
Is Electric Heating Low Carbon?
Electric heating produces no direct emissions at the point of use, there is no burning of fuel in the home. Whether it is genuinely low carbon depends on how the electricity supplying it is generated. As the UK grid becomes increasingly powered by renewables, the carbon intensity of electricity is falling steadily. Paired with solar panels and battery storage, electric heating can be very low carbon indeed.
This is the key advantage electric heating has over gas over the long term. Even if running costs are higher today, the carbon credentials will only improve as the grid gets greener.
Which electric heating system is right for me?
The key factors to consider are: how well-insulated your home is, your financial position and how much you want to reduce emissions. Direct electric heating is easy and cheap to install as it doesn’t require radiators or wet underfloor heating. However, it is usually more expensive to run once installed. It is typically suited to smaller, very well-insulated homes. Older, less-insulated properties will be less suited to electric heating as it will become very expensive to run as it’ll take more energy to heat the home.
Benefits of Electric Heating
Doesn't require a 'wet' central heating system, except for electric boilers
Low upfront cost for installation & little maintenance requirements
You can heat one room at a time, or 'top up' other heating systems flexibly
No carbon dioxide output
Electric Heating FAQs
